Hi, while working we are experiencing an issue when extracting elevation from Revit. Specifically, when the depth cueing feature is enabled, the resulting elevation PDF appears pixelated and exhibits blurriness. Currently the only option available is manually changing line weights and using template. We would appreciate solution to this issue or an alternative solution that allows for displaying level difference in elevation without enabling the depth cueing option.
