Export to PDF multiple separate sheets
Export to PDF multiple separate sheets with out save the PDF every time
that i mean if i have 120 sheets and need to exporting to PDF in separate file we must be save 120 time PDF file
7 Comments
I think this is more to do with your PDF printer settings.
Also, have you tried https://www.rtvtools.com/rtv-xporter/ ? Best $10 you ever did spend
Yes, this is already possible....been doing it for years.  It all depends on your PDF writer settings.  Adobe for example requires you to specify a default location to save files at.
sonicer
Hi
You can do that with PDF creator pdfforge. Here you can set automatic save. You only set default directory, print setting and click print.
IF you want more easy way better use PF Printer PDF.
I used this plugin in project with 650 Sheets with many different papersize
Payam_Rad
@Anonymous can you elaborate please? how can you do this in Bluebeam?
We are pleased to say that this has been implemented in Revit 2022.
-The Factory
Tarek_K
Status changed to: Gathering Support
Tarek_K
