Export DWG using naming rules from parameters like the new PDF export in Revit 2022
Add the ability to export DWG using naming rules from parameters taken from views and sheets exactly the same way the PDF export works in Revit 2022. Even have it built into the same tool as another option so PDF's and DWG's could be created at the same time.
6 Comments
atis.sed
Please! ADD THIS! I am surprised that they implemented naming system in PDF export but the DWG export stays with archaic system. If I export 20 PDF and DWG files I have to rename to add Revision number to DWG 20 files.....
gtaitRRB7N
Yes please! The naming system for pdf export is great.  It should be available when exporting any file type.
While you're looking at DWG export, maybe we could have an option to export the DWG file only, rather than including a PCP file and image files
adamCQWS2
Yes please!
dvanhornQF28K
Community Visitor
Yes please
rkheirkhah
Community Visitor
Yes, please
umut.akparlar
I cannot believe this feature has not been added yet, Revit has already got this feature, please implement it for DWG filenames too.
