to improve the bim to field workflow in site design we would be thankful if you could implement a command to export coordinate points (x,y,z) to excel or a similar text file.
it could either be the corner points of slabs/walls etc. or manually set point coordinates.
in our current workflow we have to export the revit project to dwg and set points (block) in autocad manually.
then we extract the data out of the chosen blocks and generate an excel file. (automatic command)
would it be possible to implement the same command from autocad in revit?
