Error message when attempting to move a viewport
In Revit 2026, there seems to be a bug whereby using the move command to move a viewport produces an error message that "selection cannot be copied".
2 Comments
Hi, @eitanCZ3K3 ,
This sounds like a bug. Could you file a problem report in your Autodesk Account (manage.autodesk.com)?
Also we will move this thread to the forums for support.
Thank you!
add_oz
Hi @eitanCZ3K3
Have you checked that the disjoin function is not active? If active, then you will get this error every time.
