Elevation views shall be parametric
Elevation views shall be parametric so I can select the elevation (or multiple elevations) and go to the property menu and change the top constraint or the bottom constraint similar to the way I can a wall.  If I want the elevation view to have a top constraint at the 9' ceiling I should be able to set the crop to 9'.
