Electrical Settings - Wire sizes : Edit Ampacity / insert Size Table
Wouldnt it be so Easy to just edit the ampacity in the electrical wiring settings ?
Just by adding a simple function called "edit"?
Or what about A simple insert .txt file?
nowadays i Would have to delete and create a new ampacity.
I need to write by hand these values, from a book that has over 20 schemes in it..
We really want to make te wiring circuits as real as it can get. but not when it has to take up to several weeks to edit this because of bad UI.
By Implementing a simple edit tool this you could save up so much time...
1 Comment
RakMas
Excellent idea, I wanted to edit the list earlier and found out that I have to delete the entire list and start over. Eventually I decided not to change anything and leave it at default values.
