It would be great to be able to edit certain parameters within the rooms from Linked models.
the workflow would look something like the below.
Architect creates the layout and loads the rooms into each. Additional Parameters are created for Mechanical or Electrical disciplines. these parameters could looks something like the attached or the following
Electrical Parameters - Fire Alarm Requirement, CCTV Requirement Etc.. Mechanical Parameters - Air Pressure Profile, Hvac Zoning, Sprinkler Zone Etc.
When the consultant loads in the Architectural model they are then able to fill in the parameters that are applicable to their own discipline. The information is then synced back to the Architectural model in a similar way that the Copy / Monitor Tool operates.
This allows for a fully coordinated model between consultants.
