Edit group background
I would appreciate the ability to change the background color of the group edit mode.
Have seen wishes like this before in forums, and a similar idea posted in early 2018.
My idea is to add an option with the rest of the color choices.
And as you can see, I prefer using a dark background. So every time I want to edit a group I'm almost blinded by how Revit currently is.
12 Comments
steven.steel
I would like the back ground colour to remain as is, when editing a group block.
It currently turns yellowish and is hard to see clearly.
I agree this is a huge problem, the yellow in edit group mode is yellow and blinding I'm having a very difficult time making adjustments to the MEP vent piping same color as background. Revit Please fix..!
amehner
Community Visitor
I absolutely agree. I have difficulty seeing certain colors and need a black background when I am working.  I have seen posts requesting this change dating all the way back to 2008. Please fix!
Yes, Revit ,please fix this thank you
timh
I agree as well.
It would be helpful to change the background color to something darker to make lighter linework more visible.
Thanks!
2020 this option not available to change group edit color graphic
i am getting this option only kindly advice
jimmi.opperud
@unitedmastersbim1 sorry for the confusion. That is an edited picture I made to illustrate my idea.
This colour option does not exist.
matthew.shultzSZQLZ
I use yellow selection highlighting with black background like many others, when editing groups this makes item selection completely unusable. I would like to change group edit background to a slightly lighter grey than black to be distinct, but still be able to see my selection.
sauradiptaneogi
When Edit Group that time show the background is yellow colour. How to change background black. Please Suggest.
ing_jeyssonfprieto
Community Visitor
When editing a group in Revit, the entire canvas turns yellow, which is visually jarring and reduces the readability of elements. I suggest replacing the yellow background with a more subtle visual approach — similar to family editing mode — where elements outside the group appear desaturated, dimmed, or hatched, while elements inside the group remain in full color or are highlighted. This would provide a clearer and more comfortable editing experience without sacrificing context awareness.
premont
Observer
so 6 years people have been asking for a simple background color fix and the response from autodesk.....*crickets* but you can bet if you go over your license limit a single time you'll hear from them
