Drag and drop sheets into groups
We use a parameter to group sheets conveniently so they are easy to locate. In large project we might have more than 500 sheets, grouping them is essential, so it is easy to locate e.g. a section, a sketch, or a perspective.
When making a new sheet you have to type in to the parameter where to group the sheet. This is tedious Work, and since the groups are predefined in our office standard they allready exist in all project.
My idea is to be able to make a new sheet, and then just drag and drop that sheet into the group. This would speed up the workflow, and make the grouping of sheets easier.
1 Comment
Great Idea!
Parameter setup and parameter values are used to define the browser organization properties. Drag and dropping will simply auto populate those parameters / setup to the ones present in that group / nth level subgroup.
