Detail lines do not appear from linked view
Hi All,
Refer to the topic
posted on 08-25-2016 07:37 AM
I am experiencing the same issue where the linked view is set up correctly in the source file, but the
detail lines and detail items do not appear when the view is linked into another project template or project RVT file.
Ideally, the detail lines and detail items should be displayed exactly the same when the view is linked into another project file. This would greatly improve workflow efficiency, as we could prepare all detail lines within the working file and simply link it into the project template for documentation, without having to repeatedly go back and forth to edit the details.
I hope this can be reviewed and addressed in a future version update.
Thank you.
Best regards,
Shi Chein
1 Comment
Ric_Weber
@revit8DX3PR, Shi, I presume the item that you meant to link there is https://forums.autodesk.com/t5/revit-architecture-forum/detail-lines-do-not-appear-from-linked-view/...
This is ridiculous.  When linking a model into a view by Linked View, it should be WYSIWYG, what you see is what you get.  This is similar in issue to my idea regarding revision clouds in by Linked View views, but basically the opposite!  https://forums.autodesk.com/t5/revit-ideas/by-linked-view-to-show-revision-cloud-per-the-linked-mode...
