Create schedules with analytical results from Robot
I saw this video from Autodesk building solutions YouTube channel called "integration of BIM and structural analysis" https://youtu.be/kab2WdXEUBg and and i just would like to work use the reactions from Robot in Revit Schedules without external tools (Excel) and without adding those parameters manually so the schedule calculations can be as dynamic as possible, I mean, changing the values according the design and load changes according BIM philosophy. Since it is a pretty basic function compared with the video and since there are many schedule parameters regarding analytical values (including loads and reactions). Here is the issue: https://forums.autodesk.com/t5/revit-structure-forum/scheduling-analytical-results-from-robot-in-rev...
