create half-tone options for only projection/surface
Right now it isn't possible to make projection/surface lines half tone.
Yes, ok,  its done by selecting the object and then override per instances but i want to do this with filters/visibility overrides in model categories (per category and not instances)!
4 Comments
Kimtaurus
I'm not sure if this is what you're looking for, but you can set categories to Halftone in the Visibility/Graphics Overrides window, and even use filters.
hve-architecten
No: only projection/surface lines of the category, not the whole category at once.
Kimtaurus
@hve-architecten wrote:
...its done by selecting the object and then override per instances...
If you use the "by instance" method it also halftones the whole object, cut and surface patterns.
In case of black projection/surface lines, you can use a grey line override in the category, this will mimic the halftone.
hve-architecten
@Kimtaurus
Hey thats a nice one!
That way (override projection lines with grey lines) i can use this with filters also. Much much faster then instance based.
Forma Design Contest
Technology Administrators
