Copying objects in elevation should remain on their original host Level
I've come across an issue that involves the rehosting of objects when copied within an elevation or section view. Currently, the problem arises when an object is copied and subsequently moved either horizontally or vertically, causing it to rehost to a different level.
Example: As depicted below, the copied object is now incorrectly placed on a different level.
