Copy & Paste Color / Pattern Override between override-able properties
This is a copy/paste request to be able to copy and paste properties such as patterns, color, line weight and such when we select overrides between similar dialog boxes. For example, creating a filter in a view, the cut pattern and surface patterns are overridden. To repeat many properties that are overridden is often tedious and time-consuming. If we could copy the properties from one place to another and paste it, it would save time and make it better UX experience.
7 Comments
Rab_i
Really no one would like this feature added? Perhaps I am the only one who sees this as a value. Being able to copy and paste properties from one assigned field to another seems very useful.
Yes I would also like to be able to do this for sure !!!
I ran into this again. Being able to right click and copy the properties to paste into another view filters could have saved me hours. Thank you!
MichaelRuehr
yes also in the Material Editor 3DS Max has it forever
m.aitabdallah
Yes I'm really searching this feature, itwould save time.
This free plugin has the function of Matching override graphic, which I think Revit should have the function as a default.
PYREVIT
https://revitpure.com/blog/10-amazing-pyrevit-features-to-save-insane-amounts-of-time
Rab_i
I ran into this again today. Trying to copy paste the same overrides from one setup to another. Like we copy/paste this in 3DS Max.
