CONTROL VISIBILITY OF WALL SWEEPS IN PLAN VIEWS!!
This is another huge pain and I can't believe it hasn't been fixed yet after all these years. Wall types can host wall sweeps. Such as base, chair and ceiling moldings / cornices. Great for internal perspectives & sections, but horrible for when trying to hide in plan views. Now there seems to be a checkbox inside the Visibility graphics to turn off wall sweeps as an override. Problem is, it doesn't work!
The only way to sort of get some control on the visibility of the sweeps, is to play around with the View Range. In some cases, it works, but in others, objects get hidden that you need to be shown.
78 Comments
curtisridenour
@PatrickGSR94 @ftidmore
I found that you can specify a Material to Wall Sweeps that are built into the wall. Then you can use fitdmore's view filter but use the Material property to hide them.
PatrickGSR94
@curtisridenourit doesn't work.  Filtering sweeps by material only works to sweeps applied to the wall, not ones in the wall type itself.
curtisridenour
@PatrickGSR94 it seems to work fine on the wall sweeps i added to this wall type.
PatrickGSR94
@curtisridenour
I don't know.  I made a wall with an exterior brick wainscot sweep, and an interior baseboard sweep.  I made the baseboard sweep material "Finishes - Paint - White".  I set the filter to catch wall types with a length value, and material equals "Finishes - Paint - White".  Baseboard sweep was not affected.  When I placed a sweep on a wall, and set it to that material, it DID hide that applied sweep.
curtisridenour
What version of Revit are you using? I am in R2025. See an image below of the view filter settings. It is applied to Wall Sweeps.
PatrickGSR94
It doesn't work.  With the OR function like you have it, it hides ALL sweeps in the wall type.  With just the Material setting, it doesn't work at all.  All sweeps still show up.  I want to be able to control sweeps separately (such as hiding a baseboard sweep, but showing a brick wainscot sweep), and trying to filter sweeps in a wall type, using Material, does not work.
DavidHarrington-WPM
Furthermore, if working with links, I'd like the ability to control graphics for sweeps that exist in a link. So, that means I have no ability to manipulate the materials for elements since they are within a link.
curtisridenour
I should have looked back further in the responses to this idea. @PatrickGSR94 is correct for his needs. It hides all sweeps within a wall and will not delineate between different ones based on material or profile. It is like Revit is playing a cruel joke on us. Giving you the ability to hide all (it knowing it is a wall sweep) but not different kinds based on parameters (which it most definitely has). What a huge bummer.
@kimberly_fuhrman-jones any update to the roadmap about this?
PatrickGSR94
yep, the Material rule isn't even needed if you want to hide ALL the sweeps.  Just use the Length Has a Value rule.  That seems to be the ONLY thing that will work on sweeps, as it pertains to filtering.
curtisridenour
It has been a fun little time sink to figure out a way to hide a wall sweep in a plan view today. wonderful..... /sarcasm
@curtisridenour , well that was fun! As far as the Roadmap, it looks like the teams are in the process of updating it as we speak. I will bring up this particular Accepted Idea with our product team.
curtisridenour
doblackMR4M2
Observer
pete5F4CX
YES. PLEASE. I dont use the wall sweep tool because it is more efficient to embed them as part of a Wall Type's Structure> Sweeps and have the sweeps be drawn automatically as the wall is drawn. However, if you're making a plan view for the setting out of studs, typically the builders just want dimesnions from stud centers or stud faces, so we hide the the "Non-Core Layers" which will hide the plasterboard, but this leaves the skirtings (or base-boards for you Americans) visible and appear floating off of the stud. It's nuts that I can hide a wall type's lining layers in the VG overrides in a view template but not its sweeps, only the sweeps made using the sweep tool. All the more nuts that people have been asking for this for a decade. Please AutoDesk, thanks.
GrantBIM
@pete5F4CX I don't know if you saw, but a quick work around is to create a filter that hides any wall sweep that has a length value.  I posted this back on page 2, but it is the process I use to deal with what you are describing.
PatrickGSR94
@GrantBIM except that it's all or nothing.  You can't hide some sweeps and not others.  If I have an exterior wainscot sweep and an interior baseboard sweep, I can't hide one or the other.  I can only hide all of them, or none of them.
GrantBIM
@pete5F4CX Does something like this work?  I don't know how many different types you are working with.  This would get laborious rather quickly.  Its a horrible thing to have to do, considering the solution seems rather easy from a programming perspective.  I agree with your sentiments - a decade of requests and we still don't have it sorted.
pete5F4CX
Thank you SO MUCH Grant.
