CONTOUR LABEL ORIENTATION & LABEL LINKED MODEL
Add option to flip contour label orientation to either up hill or down hill.
Allow contours in linked model to be labelled in host model.
10 Comments
All the contours are appearing upside-down (because its downhill) - not a professional look! OCD persons nightmare!
dbroad
If this is to be in conformance with a Civil Engineering drafting standard, then why does virtually every GIS system show the contour labels so they read without turning the page upside down?
dennis_collin
In Revit Versions 2022 and prior , Contour labels were readable in an ascending slope direction. This is the correct convention in UK mapping conventions and also in many other parts of the world I believe.
In Revit 2023 new functionality was introduced making the contours right reading to the Project North, no matter the slope direction. This whilst useful maybe for some is not the correct convention for site or survey drawings and there should be an option to toggle between the right reading function and the original (correct) function.
Instance or Type property (similar to TAG labels) or maybe the INI file
Refer to attached image for the desired outcome.
I was hoping for improved Site tools in 2023 but we seem to have managed to take a few steps backward with regards to toposurfaces
Tags (4)
wr.marshall
doubtful it will happen due to this idea: Contour Label Orientation - Autodesk Community which requested for label to always be project north orientated as you stated
also on the augi wish here
2007 - Keep contour labels right-side up (augi.com)
2005 - Contour Labels - Keep Readable (augi.com)
been a long requested feature!!! This being upside down could be due to CAD systems and so became the norm. Could be mistaken though!!! Maybe be solution is to have a toggle for upside down or right way up to preference!!!!
richard.cBWUYX
Community Visitor
Also Transparent Contour label as well as flipable would be handy too.
dennis_collin
The contour reading convention has been around since paper drawings, and predates CAD.
In Civil 3D there are several ways to address the right reading problem. I just think Revit deserves a similar treatment (option in instance Prop or INI or similar). It is my impression that many of the Revit feature requests are biased towards conventional Architecture. Other disciplines also need to be considered. If anything Topo is more Infrastructure than Architecture and Revit to be successful and a better product needs to cater for all disciplines, including areas like Landscaping and better Topo tools to  Cable Trunking in Revit MEP. A long road of improvements still need to be made, whilst I appreciate things are always more complicated than they might seem making improvement progress slow. It is immensely frustrating to go backwards!
dennis_collin
Several months and hotfixes later, but still no bananas! 😛
Mumbles post schedules within railings, legends, undercutting topo.. etc.... Complicated? But label orientation must be an easy fix?
dennis_collin
Fantastic!
The defect has been resolved with the 2024 release and the introduction of Toposolids.
Contours now read 'up the hill' as per every convention I can think of.
This is not documented fix but am happy with the new corrected functionality.
Brilliant , I can now 'sell' Revit as an OK site modelling tool!
wr.marshall
@dennis_collin think this is broken again for your prefrence!!!
There should some sort flip switch so that you could both ways as shown below. If there is a flip switch I couldn't find it!!!
Ref: see my comment above on 05-09-2022
(1)always upside
Screen shot from Revit 2025
(2)upside down. (as per @dennis_collin request)
In addition to the original ask (@Anonymous) cannot label contour in host model
dennis_collin
*Bangs head on desk*, with Revit taking 1 step forward and then 5 steps back!
Thanks  @wr.marshall for the heads up on this returning problem, and yes on the other matter, surely we should be able to tag toposolids in linked models? We can do it with other categories/tasks!
Makes most of the 'improvements' for toposolids in 2025 useless. IMHO. Awaits a for a hotfix with eager anticipation.
Forma Design Contest
