Component Stair End in Landing
Currently, the process for creating a component stair that ends in a landing is a bit sloppy and requires manual edits and other workarounds. It would be create to include a check box in the stair type to include the creation of a landing at the end of a stair run. This would also help clean up stair railings (which deserve their own idea post). Thanks.
5 Comments
Kimtaurus
Not just ending with a landing is necessary, sometimes we need to start with a landing.
tolga.isikyildiz
an option like “end stair with landing” (or ability to add landing for single run or between two runs of two different multistory stair run) would help to;
1- Avoid the extra work to end Multistory stairs with floor (create a dedicated floor type, adjust to treads etc.)
FACT: Landings between stair runs and landings connecting stair to the level generally have the same features; like same floor layers,  same material, structural thickness etc.
2- Use just one “shaft” element to cut the floors throughout the levels. Otherwise we might have as much shafts as we have different level heights.
Tags (3)
Atafs
Why not just create  a floor for a landing?
tolga.isikyildiz
Hey @Atafs
Especially when we think about a stair in a dedicated shaft (i.e. a fire escape stair)
1-  The last landing (or the landing connecting two stairs on a multistory stair) is still technically a landing. It would have the same features like the other landings. (now we have to introduce an extra floor type exactly as stair landing. And the quantity is not counted for stair)
2- Since Shafts are cutting floors but not stairs; it would be much easier to have a single shaft running through a high rise building stair shaft (now we have to arrange floors accordingly on each different stair composition on different levels, or have multiple shafts on different levels accordingly. And we have to revise them as needed every now and then)
3- Precast stairs will have correct connection to levels (now, they are not connecting to floors as required)
4- Stair sections will be all seamless (now we have to apply some overrides)
