Please could we have the ability to combine dimension strings.
Splitting dimensions is great, thank you. But if someone has created a bunch of single dimensions, or accidentally broken a string and can no longer undo the action, it would be really helpful to be able re-combine.
A way to integrate this (from an end-user perspective) could be using the 'edit witness lines' of one dimension string to select another dimension string to combine the two?
Thank you for your time.
