Color Styles - Custom Color Book
In Revit, you can change the thickness of element's lines by choosing from a predefined list (1, 2, 3, 4...).
For each line weight, you can define what each weight number corresponds to according to the scale.
But when choosing colors, you can select between direct colors and predefined and non-customizable color books.
My idea is to be able to create a kind of custom color book, just like with line weights works, so you could go to
Manage/Additional settings pulldown/Custom Colors
And you can create color1, color2, color3... and decide what each one corresponds to.
So, if you select color 2 to a line style, a category in VG, etc., later in the project you could change what color 2 corresponds to, and it will change throughout the entire project at once.
This way, it would be possible to create your own project color book, maintaining color consistency and allowing you to speed up the workflow when needed.
Example: Imagine having to produce all the documentation for a competition and your boss decides that terracotta isn't the exact shade he wanted, and tells you to change it by half a shade.
You have to go view template by view template, changing it and checking that nothing has been changed per element...
vs.
Manage/Additional settings/Custom Colors -> Change Color 1
3 Comments
Mike.FORM
I could see something like pictured. You would have a drop down of all the colors in the custom color set and then you could check a locked box if you don't want the color to ever change. If you want it to be able to change when changing the color in the color set, then you would leave it unchecked.
It may also make the current 16 custom colors obsolete.
In addition you could also have a drop down for what color set you want to use and then be able to make more than one in the additional settings location.
So you could have sets like, Earth Tones or Pastels and then have multiple colors assigned to each set.
arq_42
Well, that color screen is quite old; I think it already existed in Windows 95 Paint, so yes, it's a bit outdated, haha.
I was thinking of a window similar to the Line Weights window, but as you mentioned, you could have several sets and add/remove numbers and colors in each set.
I'm even thinking that each set could be a different view discipline (Coordination-AR-MEP-STR), and if you change the discipline, all the colors change at once.
It could have great potential!
Mike.FORM
Yeah I was thinking my image would be for the application of the colors.
What you show would be the actual UI for creating the different sets.
Could also use something similar to the Color Scheme UI.
