Color by Parameter in Temporary View
Revit has a very useful feature called “Worksharing Display Modes” in the temporary view settings, which allows elements to be quickly and clearly color-coded.
This functionality should not be limited to worksharing—it should be available for any parameter.
Currently, for other parameters, you need to create a separate filter for each parameter value and assign colors in every view. This is extremely time-consuming and inflexible.
There should be a temporary display setting where users can select a parameter and automatically assign or adjust colors based on its values. This would allow dynamic color differentiation without the need to create complex filters.
