Circular crop view
Circular crop view
The possibility to create a circular crop view region.
2 Comments
fred2193
it is possible, by creating an empty 2d view in 1:1 with a filled region with a circular opening. Place the view that needs to be cropped on a sheet. Then place your view with your filled region on top of that, on your sheet. if it doesn't print right, you can screenshot your cropped view from revit and insert it as an image file instead. not a very efficient approach, I know 🙂
ben.bishoff
A possible workaround - use a polygon with lots of sides - 36 max is allowed. That's getting close to a circle!?!
