Change LW and Linestyle of grid lines,section lines and callout boundaries in VG
I would appreciate an ability to change linestyle and lineweight of grid lines, section lines and callout boundaries in Visibility/Graphics window and View Templates.
When we´re sharing the same model - central model - with architects (we´re structural designers), we would like to use different lineweights and linestyles than architects, but now it´s not possible, because this options can be changed only in Object Styles.
1 Comment
ipselute
Use Copy-Monitor command to create your own grid lines. Then you can change the format as you want. You can even add more, secondary grid lines if you need so. Sometimes, architects are not making structural-sound grid lines, engineers need to adjust them for technological purposes. In any case, you need a way to show the architect your intent: the new location of the grid lines versus the original location. That's why we duplicate-edit the original grid lines.
