Categorize Tabbed Views
The new tabbed views feature in Revit 2019 is great! Thank you for it.
It is a bit confusing when you have multiple project files open. You might have views in different projects that are the same name. It would be great if you can categorize the tabs per project by using color coding for example.
262 Comments
steiner
This is already realised in PyRevit 4.8.7. https://github.com/eirannejad/pyRevit/releases
Cheers
Adrian_2D
I'm surly not the onlyone using multiple banners while fixing a family/ copying from project to another. It would be a bit easyer to work with multiple banners if they could get a colour sorted by the open file or something like that.Revit_G5XVYQBCdOAutodesk_Revit_2020.2.4_-_[Project1_-_Floor_Plan_210517d.png
Made a qiuck exsample image..
Hi, @Adrian_2D ,
This has certainly been a popular topic...here are some similar Ideas, and with your permission I would like to merge yours with these:
Categorize Tabbed Views - Autodesk Community
Color Code Different Project Tabs Within Revit - Autodesk Community
Thank you for your submission!
Kimberly
RevitBuilder43
Try this solution, link in the description to the attached video
https://www.youtube.com/watch?v=b0PXfTu7xyw
RevitBuilder43
lionel.kai
FYI, for those using the free pyRevit, I recommend these colors over the defaults (pastels, so text stays black):
  1. tab_colors = ["#FFFBDEAE","#FFC8D5E1","#FFAAAAFF","#FFAAFFAA","#FFFFFFAA","#FFAAD5FF","#FFFFC1AA","#FFAAFFFF","#FFDDEEBB","#FFFFAAD9"]
which can be copied into:
  1. C:\Users\<username>\AppData\Roaming\pyRevit\pyRevit_config.ini
I use "Background Fill" for projects, and "Border - Heavier" for families
RevitBuilder43
You can use a ready-made ADD-ON to COLORIZE YOUR TABS.
I attach a video of coloring tabs by belonging to open projects Autodesk Revit
Video on YouTube:   https://youtu.be/b0PXfTu7xyw
Colorizing Tabs In Autodesk RevitColorizing Tabs In Autodesk Revit
Theme In Autodesk RevitTheme In Autodesk Revit
Link: https://youtu.be/b0PXfTu7xyw
RevitBuilder43
The functionality you need is already available in the Autodesk Apps Store
Add-on here:  https://apps.autodesk.com/RVT/ru/Detail/Index?id=6172229355984601104&appLang=en&os=Win64
RevitBuilder43
johnharwood5
I downloaded it but it doesn't show in add ins.
lionel.kai
@RevitBuilder43 Can you please stop flooding this IDEA thread with ads for your app? One or two posts are more than enough, especially when there's already a free alternative available (pyRevit). When you post, a simple "this is what my app does better than the free one" list of features (with ONE link) would be sufficient to let people know about your alternative and send interested traffic your way.
Workarounds (including add-ins) for idea requests are MORE than welcome (as a stopgap), but this thread's MAIN purpose is to try to get Autodesk to incorporate the requested feature in the core product, NOT as a platform to advertise your add-in.
EDIT: Not to mention that many of your spam posts are in completely unrelated threads such as "Code signing of Revit Addins"!
johnharwood5
I think you sent this to the wrong person
hkropp
Observer
I frequently have multiple tabs open and can be a mix of projects and families where the name on the tabs is the same from one project or family to another.  It would be nice to have some sort of designation on the tab as to which project/family it is without me clicking through each one to find the thing I am looking for.  Could be as simple as a nickname, project number or an abbreviation of the project file name to help differentiate it from another.
Tags (2)
MiWolff
Installing pyRevit (which is free and installable without administrator rights) will give you coloured coded bars above the tabs, those belonging to a family editor get a rectangle. No nicknames though.
Hi, @hkropp ,
There are several similar Ideas that we will combine with yours. Thank you for your Idea submission!
-Kimberly
atis.sed
@kimberly_fuhrman-jones thank you! Hope to see this as an update, because this is long wanted feature!
Fabian.OswaldS52TK
Does anyone know where in the AdWindows I can find the property to change the color of each drawing tab? Thx
giovannibrogiolo6744
Hi Fabian,
Any reason to use AdWindows instead of System.Windows.Controls?
You can set the BorderBrush and Background color of a TabItem. Please see here:
https://github.com/eirannejad/pyRevit/blob/4afd56ccb4d77e4e0228b8e64d80d1f541bc791e/pyrevitlib/pyrev...
and here (an extract of pyRevit code):
https://github.com/giobel/ReviTab/blob/master/ReviTab/Buttons%20Zero%20State/ColorTab.cs
Paul_F_Aubin
I frequently work with two side-by-side tiles. In each tile, I often have multiple tabs open. If you open a new view, it goes to the active tab. It would be nice if I could designate into which tab a newly opened view would go. This would prevent needing to drag it over to the other tile. So for example, I could designate my left side tile for floor plans and 3D and my right for sections.
kythemc
check out PyRevit.... it Colors the Tabs.
