I don't know if this sounds familiar to anyone or that I'm missing out on something, but I have the following issue.
When opening a project with a new Revit version, the model will be upgraded. This also temporarily happens to the linked models within the project. But this can take a very long time with large linked projects. To long!
I guess the way to do it is to upgrade the linked files first, and then afterwards upgrade the host project.
However, we always obtain the Revit version in the filename of our Project files, e.g. Project_R16.rvt so that we know with which version of Revit to open the file with. (For some reason AutoDesk still does not know how to tell Revit which version of Revit to start when opening a project by double clicking an rvt-file when there is more then one Revit version installed.) Because of this, the linked file will have to be Reloaded from... the new filename and location of the upgraded linked Project in the host model. The only way to avoid the temporary upgrade process of linked files within the host project model is to remove the linked projects from the location where they are refered to within the host project model.
I would like to be able to simply cancel the temporary upgrade of linked files within a host project model.
So that I can Reload the upgraded linked files, and not have to go through the temporary upgrading process.
When I try to cancel now during the temporary upgrade, the whole project is being canceled from opening.
