Shortcut for turning on / turning off the Section Box
We have a keyboard shortcut for Section Box : BX. But it doesn't work for turning off the Section Box. It would be very useful to me to select an object, then Section Box it, edit the object, then turn off the Section box, select another object, Section Box it, and so on. Reusing the same view would save a lot of time.
25 Comments
I would like a visibility button for the section box command to turn on or off the box in a view added to the bar at the bottom of screen near the Crop Region button.
Currently the only option is to turn the box on or off in the Extents section of the Properties Dialogue. I want it on but not visible.
I use it for plumbing stacks in a building, showing a 3D view of the stack. To turn the visibility on or off I have to go into VG/Annotations and scroll down to Section Box and pick. Very cumbersome to do when you are producing many views.
You can also drive your work associates crazy by right click -->Hide in view....
craigh_bim
@Anonymous
This is a great idea. I'd love it to be in the View Properties palette in Extents next to Crop View, Crop Region Visible, Section Box, "Section Region Visible". (just to make it match).
I've never used the crop view buttons on the View Control Bar, weirdly enough. I use it primarily for temporary overrides and temporary view templates. But I'm certainly not opposed to it being in the VCB.
Cheers,
pobrienFNE96
I'd like the option to turn section boxes in 3D views on and off with a keyboard shortcut.  Shouldn't need to scroll through view properties to do this.
elzohry2007
totaly agree
tlindenau
Observer
Hi There!
You can toggle the section box off and on with a keyboard shorcut. You must be using the (FREE) COINS Auto-Section Box plug in to use this feature though, as far as I know.
https://apps.autodesk.com/RVT/en/Detail/Index?id=8920075109543819118&appLang=en&os=Win64
1. Once you have installed and are using the COINS app you'll want to set up a keyboard shortcut for the auto-section box of course.
2. To set up the shortcut for turning the section box on and off, in your keyboard shortcuts search "toggle".
3. See below; find the Toggle for Add-Ins>COINS Section Box and create your shortcut. Mine is SR for "section release". This allows you to turn the box on and off in your 3D view. Hope this helps.
pobrienFNE96
@tlindenau that's a great (and easy to read) post. Thank you very much!
BigPicture045
With a scope-box oriented workflow, the section box feature is used extensively. Is the COINS plug-in the only shortcut solution to date?
BigPicture045
The COINS add-in works well. Now, we need a shortcut for turning on/off scope boxes in our 3D view settings without having to go into visibility settings each time.
pobrienFNE96
Too right. Having projects with 20 or so scope boxes causes performance nightmares if they're all visible.
BigPicture045
@ToanDN
This shortcut is not only changing the visibility, it is changing if the section box is on/off. It appears pyRevit only toggles the visibility.
Unchecking/turning the section box off allows for the section box area to be reset. This is helpful with the scope box workflow.
Mike.FORM
Agreed it should look something like this.
rnarracci
To add to this, it would be nice when re-activating the section box, to have the option of either using the prior setting, or resetting it entirely (which is currently the default)
conklinarchitecture
Community Visitor
A hotkey for section box is 'BX' or 'SB', depending on what version of Revit you're using. Select an object you want to isolate in a section box, and hit that hotkey. Super helpful.
revitPWC6K
it would be worth to have ability to join any shortcut for "hiding the visibility of section box"
@revitPWC6K : You can hide it in V/G -> Annotation Categories -> Search for : section , then uncheck Section and Section Box. I would very much like a shortcut for filtering and hiding Section Lines and Section Tags
Use PyRevit section box toggle tool.
pdent
PyRevit section box toggle works perfectly, and you can add it to the quick access toolbar. Thanks @ToanDN
wr.marshall
As wish states a quick on/off button for 3D section box perhaps in the view control bar and only visible when in 3D view. This would be time saver, rather than going into visibility graphics each time to turn on/off
Hopefully down the road if and when this related idea is added: https://forums.autodesk.com/t5/revit-ideas/inverted-section-box-isometric-sections/idi-p/13763789
options can be made on the `button for quick on/off to invert the 3D section box
