Block Viewport
Block Viewport
There should be the possibility of blocking the location of the viewport and its contents in the plans, because if for some reason a building changes its location, all the views already taken are lost and must be reordered and when there are several plans the time in re order the views is increased
4 Comments
Kimtaurus
Use a seperate RVT project for the site/surroundings and link with shared coordinates. This way you can move the building if needed and keep al the views the same.
Renato.94
Will it work with more than one building within the same project?
regards
Kimtaurus
Yes, that how our office, and many others, work. 1 file for the site, and several files for each building.
Scott_D_
If you use scope boxes this does not happen, they follow the coordinate system when it moves afaik
