BIM 360 File Paths
BIM 360 File Paths
We want to move our template and library resources to BIM 360, however file paths to BIM 360 include the local Users folder. That means a common file path can't be set at deployment with an initialization file. Revit won't read a wildcard for the Users folder, either. As it stands, the file paths must be set manually after deployment. A resolution would be very helpful.
2 Comments
Todd_Jacobs
iberryYSP74
Community Visitor
Where is the file path - where are all the file paths - to ALL documents and ALL folders
We have to put the full file path in our extensive documents (because links are not allowed can you believe ? No me neither)
I need a column for every folder and every file on every page with the file path on it -thank you.
Kind Regards
IanBB
