Better Interface for Coordinates commands
The Coordinates command buttons are super counter intuitive. There is no explanation window for the entire process. You should at least copy the Coordinates prompt window from Civil3d if not better. Shared Coordinates between rvt files should be forbidden. Instead, all rvt files with objects should be linked into a dedicated coordination file with specific extension, an exchange file with Civil3d.
1 Comment
Not every project has civil 3D files - I dare to say less than 0,1% has and I'm already skipping the small projects/offices.
The possibility to georeference needs to be able to be done directly in revit (maybe in a similar way as in civil 3D) - don't make it dependent on a 3rd party software because it will not be done if you do. That's the reason I will not vote for this idea.
I still agree that coordination information should be better in revit because of IFC export to other softwares that may be able to do convertions like civil 3D.
