Beam System - modify Elevation of Start and End
I would like to be able to modify the start and end elevation of beam system, not only the "global system elevation".
It's common to have a beam system that span from a beam  that have joists sitting on it (elevation -100) to an other that has not (elevation 0).
I can modify the beam elevation of every beam in the system. But it's long to do and I lose the "automatic level adjustment" (in case of later changes) by doing this.
Actually, I can edit the level of the whole system. But it would greatly help if I could also determine the level of the start and the end of the sytem.
I have attached a file to help visualise.
4 Comments
ipselute
Maybe you could create a sloped reference plane and align that beam system to that plane.
sdijanovic
Hi @Evalucia
I think the beams and beam systems already behave as intended. Please try to use the "z-Offset" parameter to offset the beam for the depth you need in order to support steel joists sitting on top of it.
Evalucia
Hi @sdijanovic
Thank you for your answer. I tried it today and it work just right.
It would have been more intuitive for me if it was in the properties of the "beam system", but now that I know the right way, I don't have to bother about it anymore so it's really nice !
Have a nice day!
HU5TLE
Is there a way to do this for the whole beam system??
1. Yes, I can offset each beam of the beam system via z-offset, but then I have to do it for each one
2. It seems like there was an option to change elevation of beam system at one point, don't see it any longer
3. I also don't see the disassociate from plane option?
Video demonstrating the issues
https://www.loom.com/share/00231fd8931346afabea16ff9bcef7f5?sharedAppSource=personal_library
