Batch Split and Numerically Control Multiple Section Markers
Allow batch splitting and numerical control of section markers
Revit currently requires each section marker to be selected, split and adjusted manually.
For a plan containing 30 section markers, this means at least 30 split operations and 60 manual endpoint adjustments.
Requested workflow:
  1. Select multiple section markers.
  2. Apply Split Segment to all selected markers.
  3. Enter numerical lengths for both branches.
  4. Adjust only exceptional markers manually.
The Revit API should also expose the split state, split point, segments and segment endpoints so that this workflow can be automated with pyRevit.
This would eliminate a highly repetitive graphical task on projects containing many sections.
Cordialement,
Arthur GAPANY
