cancelar
Mostrando los resultados de
Quiere decir:
Batch plot various file formats
It is annoying to print PDF, then export DWG and then export DWF for submissions every time one by one. Cant we have a single click export for all these file formats if we preset the export views and all the settings. Something linke below, Check all the "Export To" boxes and you get the entire package while you are drinking coffee.
(I tried to create an API for this, but unfortunately its not working and think that this should be a default option in Revit.)
1 Comentario
No aplicable
Whenever I make a change, I need to export my model in several different formats for all the different trades and their prefferred format, NWC, DWG, PDF, CSV, and upload to glue.  Is there any way you can set this up so I could have an export setting do all of this at once?
Enviar idea
