Automatically expand Formula bar when typing long formulas
When typing long formulas for parameters inside families, i can't see the entire formula and it's difficult to add parenthesis in the right spots when needed. By automatically expanding the formula bar to see the entire formula, like in Excel, it is much easier to understand the entire formula and much easier to correct the syntax when needed.
8 Comments
The formula box in the parameters dialog can't really be resized very well. Perhaps add the ability to resize and wrap the contents like MS Excel's formula bar, OR add the zoom function like MS Access which opens a larger box that wraps strings inside it for easier formula editing.
Tags (2)
dplumb_BWBR
Not what you're asking for, but I use NotePad++ when I have to edit a long formula.
You can indent your tests, and NotePad++ has a parenthesis matching feature that's invaluable once you have more than 3 sets of parenthesis.
https://notepad-plus-plus.org/
ipselute
@dplumb_BWBR That's a good advice. Thanks. The green chameleon is one of my favorites too.
Now that you're mentioning it, maybe Revit should have a built-in notepad. So we can edit all the keynotes easier. And maybe a calculator too. Like Autocad has.
wr.marshall
similar idea, but for a different part (yours is for parameters, while mine is for schedules)
Schedule Temporary Expand Text based Cells - Autodesk Community
@ipselute should we combine our ideas for this case, even though two different aspects, but the idea will benefit both aspects of Revit (likely other areas too!!!).
If so Please advise @kimberly_fuhrman-jones to do so.
ipselute
@kimberly.fuhrman If you believe this ideas and Schedule Temporary Expand Text based Cells - Autodesk Community idea can be merged, please do so. I have no idea how Revit interface works, so it's up to you Autodesk guys to make the most informed decision.
I totally agree with that, it's really annoying when you can't see the entire line of code or formula because seeing all of your code helps in understanding what it does. I think the best solution to this problem would be to expand the row with the formula you're editing and break up the formula if it doesn't fit.
Nurlan-A.
LoganAC34
Bump. This would be super helpful! I currently copy paste formulas from Revit to Notepad++ and manually format the formulas with intents, but it's tedious and it would be nice for Revit to have this built in with an editor!
