Object weight should be built-in parameter for all categories and objects, assemblies etc. Weight is as important parameter as length or volume. It should be calculated from current material(s) density values. If the object does not have physical attributes (density) the weight should be possible to fill manually.
For example walls including multiple layers of different materials the automatic calculation of weight would ease many workflows.
