I would like the ability for the staircase command to automatically cut a hole in the upper slab when placing the staircase.
This is would need to following options (at very least).
- Create hole (Y/N)
- The head room clearance required over the staircase (to suit various regulations etc.)
- Boundary gap between the sides of the staircase riser and the hole required when not against a wall at the point of penetration.
- I am sure that lots more may be useful but we need to start somewhere.
It may be that the tool simply projects a line into the Boundary of the floor above and then the floor above is then updated once the staircase command is finished (to be changed in the Floor> Edit Boundary command later if the staircase is altered).
It would of course be better if the cutaway was dynamic from within the staircase edit tool.
it tool.
