Area Boundary Pick Lines
Provide ability to select multiple walls at once using a selection window similar to the way you can when creating columns at grid intersections. When integrating Revit models to space management systems often there needs to be a one to one relationship between Revit Rooms and Revit Areas in order to get the proper area for each Room per the appropriate area calculations. Having a way to mass select walls that represent boundaries would increase the speed to create these and other Area Plan drawings.
1 Comment
dtpeter2901
I have a feeling this is  all falling on deaf ears.  Autodesk got this tool about 90% right.  You can't even Automatically Place Area object in enclosed boundaries.
