when designing a building you're often considering the open space a person needs to move freely (for example the space you need in a hallway, the space someone in a wheelchair needs to move in a building, ...)
It would be more beneficial if the people content elements would not be considered as an obstacle in a route analysis but would have an analysis funtction that checks if there are any obstacles in between the circle.
It could be pretty much the same function as the path of travel where you can choose what categories are considered obstacles.
It would also be usefull to run this analysis on all "people content" elements of the same type so you could analyse if a building is compatible for people with a disability.
If these families would get their own category you could still use the previous functionality to analyse social distancing but you can also choose to only check against other categories with the same options as the route analysis options.
