ALT-CODES
ALT-CODES
You need to create a symbol toolbar like you have in AutoCAD. Having to press ALT then using the number pad to generate alt-codes are great but in your 2017 version its more sensitive to not to work since ALT is also the tool to show all the commands on you command bar.
4 Comments
dplumb_BWBR
Yes that's exactly what I'm talking about the only bad thing is that its in 2018 not 2017. I don't understand why this was not in any other previous versions.
loboarch
The text component used in previous versions of Revit did not support this. Once that was updated, the alt codes could be included. Since this has been implemented, is it ok if I delete this idea?
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months and as such we will not be pursuing it at this time. Please feel free to re-word (titles and clear descriptions are really important) and resubmit this Idea.
