Allow Selected all instances when editing a group
When editing a group Select all Instances is greyed out... why?
This command is really useful. Fix it so it works when editing a group.
Even better add some options when group editing like Select All Instances within Group
16 Comments
Being able to Select All Instances of a particular element, say a Wall Type, for instance, while in Group Editing model.
Such would allow for changing instance parameters in bulk quicker.
That would be really helpful. It is very annoying to select every single element individually now.
Please activate select all instances in edit group.
You can select the wall type outside the group (using TAB until the instant is selected) then >Select similar >isolate Elements > Edit group
Of course I can. But it is an idea to make it easier and I ask why the menu is disable in group edit mode. The problem is, sometimes when you select elements out of editing mode of group and then you are going to change to something else it will be ungrouped. Not all the times but sometimes and this is why I ask for enabling this feature in edit group mode.
Thank you
GHASEM_ARIYANI
Hello AutoDesk Revit Team
Select All Instances in the Group Editor not Working. If this feature is active it can be very helpful.
hobyrne.ca
More enhanced functionality in group edit mode would be good too... for instance, one cannot create a duct from a connector like one can in regular modeling mode.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
andrew8QEC8
 I found a limited workaround. Once in the group use the mouse to select everything, then use the filters to filter out everything you do not want. This still has the limits of what you can filter out with the multi-select tool.
Accepted:
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
 The Factory
jfk3BUD8
Hi Autodesk
When editing detail or model groups, please make et possible to select all while editing the group.
t_vanrooijA94QJ
Dear Autodesk,
This issue still isn't resolved, and I can't seem to find it on the Revit Public Roadmap anymore. Could somebody pick this up again?
@t_vanrooijA94QJ ,
This is still in our teams' backlog but has not yet hit our public roadmap. ("Note that Accepted Ideas may not be immediately available." above) Stay tuned!
rcrdzmmrmnn
Yes! And also the select all in view command please
kadenk3AKS5
Multiple Elements get put into a group. To edit an instance parameter on those elements you currently have to try to isolate and manually select, or you have to open the Group Editor, which then has no project context, so you better hope you have a good memory.
It would be incredibly help to simply have the "Select All in Project" and "Select All in View" commands available when editing a group in-place.
Thanks for the consideration!
Tags (5)
kadenk3AKS5
It would be incredibly help to simply have the "Select All" and "Select in View" commands available when editing a group in-place.
Tags (5)
