Allow plates and bolts to be edited once part of a custom steel connection
See the issue in this thread https://forums.autodesk.com/t5/revit-structure-forum/rvt20-modify-plate-inside-custom-connection/td-...
If a custom connection is created which contains plates and or bolts these components can't be edited (parameters changed, boundary edited, etc) when in "Edit" mode of the custom connection - they can only be removed which then deletes them from the model. The only workaround I have found is to create replacement plates/bolts in place outside of the connection and then remove (delete) the old plates/bolts and add the new ones when in "edit" mode of the connection.
3 Comments
piotr_pysz
Hi - this idea is in progress on our Roadmap.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
 The Factory
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Custom Steel Connections Enhancements | Autodesk
 -The Factory
