Allow Material to show on floors in sections where shaft would show face (surface) of floor.
I have separate patterns set for Concrete that is being cut vs surface.  However in elevations and in building sections example, building section thru an elevator shaft, cut slabs on either side show the cut pattern, but my view extents show the slab in surface, however the surface pattern assigned to the material does not show.  It's just white.  I would like for the materials to actually show in all views that a material is either cut or surface.  Sections and elevations specifically.
