Align Wall Material Cut Pattern to Wall Layer Boundaries material surface, not to Wall exterior surface (as today).
Today:
If for a Fill Pattern (hatch), "Orientation in Host Layers" is set to "Align with element", it aligns to the exterior side of the wall, when used as cut pattern for a wall material. This might look good for a wall consisting of only one layer, but as you add more layers to the exterior, they will hide parts of the pattern of the original layer. One might expect the pattern to follow the material boundaries, but this is not the case today. This is then less useful, since one can only control the direction of the hatch, not the starting point.
Proposed future behaviour:
If for a Fill Pattern (hatch), "Orientation in Host Layers" is set to "Align with element", it aligns to the exterior boundary of the wall layer (compound layer / wall material), when used as cut pattern for the wall material assigned to the wall layer. In a wall with several layers, each layer will have hatches perfectly aligned (both direction and origin) with the wall material boundaries.
When would this be useful?
Until Revit allows Fill Patterns of type Model (not just Drafting) to be used as Cut Patterns in materials, this feature would allow more precise hatching of cut walls. It would for example be possible to create an insulation batten hatch that looks good in 1:50 (scale the hatch for each import, to correspond to a given insulation thickness). In 1:100 or 1:200, Cut Patterns could be turned of (wall Detail Level set to “Coarse”). For details of scale 1:5, Detail Items could be used to mask the hatch.
Next step:
Allow View Scale aware Fill Patterns (of type Model, not just Drafting) to be used as Cut Patterns. One Fill Pattern could then be used for all scales, 1:5, 1:50, 1:100. There would be no need to hide or mask the Cut pattern.
