I don't condone the useless addition of AI in every software there is just to hop on a trend.. HOWEVER it would be really useful to be abele to explain to an AI what you expect to see in your view and have it tell you what steps are needed to get that visual or why it currently is not displayed the way you want.
For excample you may place a window and dont see it in your floorplan. You could ask the AI why the window you placed last- or the window you selected from another view is not visible in this floorplan and it could tell you that there is a filter active that overrides its visibility or that it is outside of your view range etc.
This would be a good workaround to find out which of the dozens of different settings that can influence element visibility in a plan you need to change to get the desired result.
