Advance Steel Extension - Remove an association
when I import in Revit the smlx file, the plugin ask me the "unknow section" in order to create the association from AS to RVT and viceversa.
You can select a section, by a drop-down list or load the family in case are missing.
If I don't have the family I can't return at the "empty" status in order to skip the association.
This is a unlucky situation because I have only two possibilities:
  1. Use the "Cancel" button and then loose all associations that I already assigned
  2. Assign a default section, but, in this case, this wrong record is stored inside the GTC Mapping table
Thank you.
