Adjusting View Range in Elevation
It will be very useful for us to be able to adjust the view range in elevation by using numbers or just draging it to the level you want it at. I think this can easily be done, the idea of the graphic showing you how to use it is a step closer to being able to interact with it.
1 Comment
Ric_Weber
So you're NOT saying to able to adjust some random floor plan view range in some random elevation.
You're saying you want the Sample View Range in the View Range dialog to be interactive????
I'd be happy if they'd update the graphic on the RCP to correctly reflect how a RCP view range works.  And along with that, change the order of the RCP View Range fields in the dialog so they are in proper order.
