Adding import DWF command to revit lt
The urgent need to add the command import DWF/DWFX to REVIT LT.
In the last year we/the architect in Israel are being asked to deliver plans in a DWF format to all the city halls and to work with a robot that sent us back the area plans we did in DWF format which we have to insert as is in our plans next to the other sections and fronts. Because otherwise they can’t check it and sent us back with all the comments to correct.
They do not agree t check it as JPG file because it cannot be majored by them.
In Revit LT it is not a possible command to import only to export and that make’s it not possible to work with the system at the moment and to fine other options or other programs… I really prefer to continue to work with Revit LT and cannot afford to pay for the full Revit/
I am Shure I am not the only one…
I would be very grateful if you can add this option.
