Add steps at bottom of stairs without remaking them from scratch
Think title is self explanatory.
Right now, as far as I know, if we want to add steps to a stair at the bottom, after making all the landing and dimentions on the desired location (because we need to increase the height of the stair at some point in the development of the project - and that happens a lot), the only way is to redraw all the stair stairting from the new first step.
There should be an easier way to revit to allow the stair to extend bottom and them move it one step up, or something simple like that.
I would really apreciate this feature, because this problem happen quite a lot, and is really time consuming!
1 Comment
Refer to https://www.revitcity.com/forums.php?action=viewthread&thread_id=33610
I had this error a lot but then found the difference between the triangle and the dot. Still not intuitive and sometimes would be easier to extend and then move - i.e. error changed to a warning until you 'finish' the stair editing.
