Add rooms and spaces into phases and design options
It would be nice if you could have rooms and spaces display a phase, so you dont have to place them as a new object after switching the phase of your plan.
Spaces should also, like rooms, have the option of including them in a design option.
12 Comments
Currently we can not place spaces in the same way as room so have them in different design options.
Design option is great feature and allow export separate gbXML  from one model but there is issue with spaces. They can only be placed in the main option. Please fix it.
Tags (2)
dplumb_BWBR
This causes us a lot of problems when we - as Architects - need to use Design Options and our MEP consultants can't.
Orsolya.Balazs
Autodesk Support
Wish on behalf of a user from Germany:
Currently it is not possible to add MEP-spaces to design options. Wish- make this feature available in the design options.
Tags (3)
wrtetro
Design options are used often with our consultants, for a work around, we phase our project for this so we can maintain full loads on our panels and know what the breaker size, etc will need to be if that option is chosen, not really a bug deal, it's chosen and we just combine the phase, but what is a big deal, is that spaces to not work with design options.  We use these spaces for calculations here quite often and without these spaces, we cant efficiently perform these calcs, especially as the model is changing architecturally.  We use a work around of either a room tag or by using space separation lines, but this is tedious.  Can you add the ability for us MEP folks to be able to add and update space names automatically for design options?
Tags (1)
dplumb_BWBR
Totally agree. Even for architecture rooms should only define the physical boundaries in the model (bound by walls etc) and spaces use of those rooms. EG: If a house has an open living area the room is the living area, spaces define Kitchen, dining, lounge uses within it etc
We have the same problem.
We receive Architecture models with design options and we can't do MEP studies by the same way.
I'm surprised that the problem hasn't been solved since 2016.
cprettyman
At present, spaces only see the 'primary' option in any linked models when finding boundaries; creating spaces that are bound by walls, or boundary lines, or whatever in options other than the primary option is not possible.
The request is for a means of associating a space in my model with a specific option in a linked model.  Note that designating that option as primary may not be an acceptable work around -
- At present, the projects are frequently on BIM360 so I may not have the rights to modify someone else's model (and it's poor practice, to say the least, to modify other companies models)
- the authors of the linked model may have very good reasons for designating another option as primary
I think one approach to consider would be to add a means to associate a design option in a parent model with design options in a linked model - but that's just one thought.
_mames
MEP user here. This is messing up my current project right now. Architects are using design options and I am using spaces based off their rooms to automatically calculate my ventilation air values. As of now I need to cheat it and this is unacceptable.
Hi, @t.huentelerCJMGC ,
Thank you for your Idea submission. Here is another Revit Idea on rooms and phases. Feel free to add your vote there, too. We are unable to combine them since the Design Option mention makes your Idea unique.
Phasing Rooms - Autodesk Community
matthew.ross.hdrinc
I'm also having this problem. It's tough to do calculations in spaces where design options exist. They must be inputted manually.
curtisridenour
The fact that you can do rooms and volume calculations but not spaces within options seems like laziness. What a bummer.
