Currently there isn't a way to select multiple items in a linked model.
So as an example, let's say you've got a bathroom showing in an architects model you need to hide in your plans. It's a couple of walls, a door and some plumbing fixtures, and maybe a few other items. If you want to hide this in your MEP model, you have to "tab select" every item individually and then hide. It's very tedious and error prone. If you have to do a large area it can take forever.
A second example could be if you've got conduits modelled for Low Voltage in an electrical model and you need to hand those off to a technology designer once they get involved in a project.
It would be great if you could use the same selection tools you have in-model to select those in a linked model. Here are a few of the tools:
- Tab select a connected system of elements (walls, pipe runs, electrical circuits, etc).
- Window select (both directions) all items
- Right-click select all instance in view or model.
- Control click to select multiple items. (This is currently allowed but the tab clicking makes it really clunky.
This could be implemented as a button/mode on the bottom right. Click the button, prompt for which model you want to select from. Then give access to the native tools listed above into that model.
