It would be very useful to activate the possibility to change the Elevation from Level Parameter when working with face-based Families in the Revit project.
The current functionality is when loading a face-based family into the Revit project the parameter Elevation from Level is grey out. The only method for changing the elevation of the element is to pick another level/reference plane or face as a reference for the element. When it is necessary to place multiple elements on different elevations, it is required to create an additional reference for each element, because it is not possible to enter a different elevation value from the level for each element. This workflow is time-consuming and gives limited space to manipulate the placement of elements.
The needed functionality will be the possibility to type/change the value for Elevation from Level Parameter in order to place multiple elements based on the same level but with a different offset.
